[GRASS-user] SQLite - Mac OS X
    Maciek Sieczka
    werchowyna at epf.pl
    Thu Jun  1 16:37:48 EDT 2006
On Wed, 31 May 2006 18:44:46 -0600
Dave Kent <dkent at sasktel.net> wrote:
> Hi all:
> I am trying to move to SQLite database from dbf using latest CVS
> (Mr. Moretti binaries, 30 May 06)  on Mac 10.4.
> I have not installed SQLite but am using the version embedded in
> Tiger 10.4  Is this sufficient?
> I have successfully imported a small .shp file and viewed it with
> SQLite Database Browser.
> db.connect works.
> db.test returns all OK except for
> 	RESULT: OK
> 	select c1 from grass_test1 where d1 < 500 / 2 and i1 <> 2
> and c1 ~ 'bc'
> 	-SQLite driver error:
> 	Error in sqlite3_prepare():select c1 from grass_test1 where
> d1 < 500 / 2 and i1 <> 2  and c1 ~ 'bc'
> 	near "~": syntax error
See: http://intevation.de/rt/webrt?serial_num=4056
Maybe this sheds some light.
> I have a problem importing a points file with v.in.ascii.  The
> import works well with dbf driver.  When I change to SQLite driver
> (no other changes) I get the following error:
> 	Length of column 3 (-1) is less than maximum value length (9)
> I have specified column 3 as 'name1 varchar(30)'  Is there a
> different syntax to specify character string variables in SQLite?
Don't know.
But note sqlite might have issues with column types in general, eg.:
http://grass.itc.it/pipermail/grassuser/2006-May/034371.html.
Also note it could be VERY slow in some operations:
http://grass.itc.it/pipermail/grassuser/2006-February/032476.html
sqlite driver could be a really great stuff, only it needs polishing.
ANYBODY?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
