[GRASS-user] real distance analysis
Bödőcs András
bodocs at ludens.elte.hu
Sat Jun 3 04:25:13 EDT 2006
Dear Dylan, Eric, Hamish, Maciek, Michael ,
Many tahnx for your advices!!
That is what I need!!!
Regards
Andras
Bödőcs András
ELTE Institue of Archaeology
1088 Budapest, Múzeum krt 4/B.
T: +36-1-411-65-54,4855200/2916
F: +36-1-411-65-53
-----Original Message-----
From: grassuser-bounces at grass.itc.it [mailto:grassuser-bounces at grass.itc.it]
On Behalf Of Michael Barton
Sent: Friday, June 02, 2006 11:57 PM
To: dylan.beaudette at gmail.com; grassuser at grass.itc.it
Subject: Re: [GRASS-user] real distance analysis
Dylan,
Looks very nice.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Dylan Beaudette <dylan.beaudette at gmail.com>
> Reply-To: <dylan.beaudette at gmail.com>
> Date: Fri, 2 Jun 2006 12:09:26 -0700
> To: <grassuser at grass.itc.it>
> Cc: Michael Barton <michael.barton at asu.edu>
> On Friday 02 June 2006 10:30, Michael Barton wrote:
>> Hamish's reply is the closest to what you want I think. However, to
>> actually derive a buffer to define equal ground distance around a point,
I
>> think you might need a bit more explanation.
>> First create a slope map of your dem (r.slope.aspect). Then, as Hamish
>> says, run r.cost. This will calcuate a 'cost' based on the slope of the
>> map. He implies that the cost value in the cost map = the ground distance
>> to traverse each pixel (i.e., higher on steep slopes where the ground
>> distance is greater and less on flat terrain where the ground distance is
>> lower). I don't know if this is how the algorithm works or not (or also
>> includes other factors), but the references he lists will clarify. If
not,
>> you can use trig in the mapcalculator to figure ground distance using-as
he
>> says-the resolution of the map (i.e., the horizontal distance to traverse
>> each cell) and the slope of the cell.
>> Assuming that r.cost on a slope map * resolution = ground distance. You
can
>> use the resultant map to create a buffer around a point that represents
>> equal ground distance in all directions.
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>> From: Bödőcs András <bodocs at ludens.elte.hu>
>> Reply-To: <bodocs at ludens.elte.hu>
>> Date: Thu, 1 Jun 2006 22:26:32 +0200
>> Subject: [GRASS-user] real distance analysis
>> Dear All,
>> I am trying to solve the following problem, maybe does somebody an idea
and
>> can help me.. (thanx in advance)
>> I would like to examine from an exact point that territory, which is
inside
>> an determinated distance from the exact point. BUT I don't want to use
the
>> map projected distance (=Buffer zone), but the datas of a DEM.
>> I would like to measure the "really" surface, the climbing etc. For
example
>> I need the maximum distance "cirlce" (30km or 30 mph doeas not matter)
>> around a point, but measured in the "filed"(=DEM) not on the map
>> (=projected area).
>> Does somebody have an idea, who can I start with it?
>> Many thanx
>> Regards
>> Andras
>> Bödőcs András
>> ELTE Institute of Archaeology
>> Hungary
>> F: +36-1-411-65-53
> An example calculation (minus the multiplication by resolution) of
distance
> from trail to points of interest, via a slope cost map here:
> http://169.237.35.250/~dylan/temp/r.cost_example.png
> This will be part of the GRASS talk at the Where 2.0 conference, I will be
> sure to post a link to the finished presentation.
> Cheers,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
