[GRASS-user] Having trouble getting integer labels
Paul Pick
paul.pick at ec.gc.ca
Mon Jun 5 18:13:52 EDT 2006
Hi all,
I have a bunch of (integer) point data I'm trying
to contour. I've done v.in.ascii, v.surf.idw, and
r.contour. The output vector (the contour shapes)
has a 'level' attribute which is a double.
$ v.info v500contour -c
Displaying column type for database connection of layer 1:
INTEGER|cat
DOUBLE PRECISION|level
When I create labels for those contours (with v.label),
I'm getting six zeroes after the decimal. I really need
to display only integer labels, so how should I go
about that?
I'm running GRASS 6.0.0 on debian sarge.
Many thanks,
- Paul
Paul Pick <paul.pick at ec.gc.ca>
Informatics Services Unit Gagetown
Chief Information Officer Branch, Environment Canada
[CSN] 432 2082 [CIV] 506 422 2000 x 2082 [FAX] 506 422 1443
