[GRASS-user] Freetype fonts in gis.m
Wed Jun 7 16:34:56 EDT 2006
David Finlayson wrote:
> > I'm a bit behind on gism developments recently...can anyone tell me if
> > d.font.freetype is supported in gis.m? I tried using it to label some vector
> > points with today's cvs version, and it's still complaining about no monitor
> > being open. Is there a workaround instead?
> I got it to work last week, but only if I printed a 1-word text. If I
> wanted to print text with spaces in it, I needed to use quotes around
> the sentence and this caused problems with the GUI.
Neither quotes nor braces work, althoug a backslash does, e.g.:
	d.text.freetype ... text=hello\ world
This should be reported as a bug with command layers.
