[GRASS-user] Help compiling under fedore 5 - "couldn't find gdal-config"
Jachym Cepicky jachym.cepicky at centrum.cz
Sun Jun 11 06:43:02 EDT 2006
On Sun, Jun 11, 2006 at 08:14:36PM +1000, Ian Allan wrote:
> Hi Jachym
> I have tried installing just about every version of grass 6 that I can
> get my hands on. None work completely. For the last version I installed
> NVIZ would not work (starts briefly & then disappears) and r.terraflow
> was not there. That is why I have "resorted" to compiling GRASS.
> I tried your two suggestions ("locate gdal-config" & "which
> gdal-config")  but gdal-config  seems to be nowhere on my system, even
> though other gdal components are. Any more ideas?
> Many thanks
> Ian
well, I have no experiance with fedora, but you should look after
package with name similar to gdal-dev or libgdal-dev, which will contain
the file called gdal-config
if you need r.terraflow, you will have to add option --with-cxx to
configure script
NOTE: I would say, gdal-config will probably *not* be last file/package
you will be searching for. You are trying to install something from
source code and you will need lot of *-dev* packages which will most
probably not be in you system.
Jachym
P.S. You should be seeking for something like
gdal-devel-1.3.1-3.i586.rpm
> Cepicky wrote:
> >Hallo,
> >IMHO it has no sence to build 6.0.x from source, unless you do very well
> >know, why you do it. If you try "just to install GRASS" and you are
> >compiling it by your self, you should use 6.1.
> >Now to your problem
> >On Sun, Jun 11, 2006 at 06:49:31PM +1000, Ian Allan wrote:
> >>Hi
> >>I taking the advice of messages surrounding darrel maddy's nviz problem
> >>(mine too), I decided to download the    grass-6.0.2.tar.gz     source
> >>file & compile it. After typing in     CFLAGS=-g -Wall"
> >>./configure       as per the instructions I get a    "couldn't find
> >>gdal-config"     message. I have installed (and uninstalled and
> >>reinstalled)...
> >the configure script does have some options, which will help the script
> >to find necessery programs and settings, see ./configure --help
> >>gdal-1.3.1-2.i386  and
> >>gdal-bin-1.3.1-2.i386.
> >gdal-bin package should have program called gdal-config. what does
> >which gdal-config
> >or
> >locate gdal-config
> >say?
> >you should then run ./configure with path to gdal-config, e.g.:
> >./configure --with-gdal=/usr/bin/gdal-config
> >Hope, this helps
> >Jachym
> >>When I do a     "locate gdal"      I get reference to a number of files
> >>in the following directories...
> >>/usr/bin
> >>/usr/lib  ( including    libgdal.so.1   and    libgdal.so.1.9.0)
> >>/usr/share/gdal
> >>However, in no directory is there such a file called "gdal" as is
> >>suggested by the error message.
> >>On and off over the last couple of years (for days and sometimes weeks
> >>at a time) I have been trying to get GRASS working. I even  purchased a
> >>dedicated linux machine-GRASS following difficulties with cygwin-GRASS
> >>under windows. Still I could not get the full suite to work so I
> >>recently rebuilt my system using fedora core 5 in the hope that would
> >>work. Alas, more tears. I am at my witts end.
> >>P L E A S E    CAN SOMEONE HELP.
> >>Thanks
> >>Ian Allan
> >>Ian Allan
> >>Director Geocode Mapping and Analysis P/L
> >>PO Box 2072
> >>Edithvale VIC 3196
> >>Ph: + 61 3 9773 1232   Fax: + 61 3 9773 1232
> >>Mob: 0429 941 527
> >>Email: iallan at geocode.com.au
> >>Web: www.geocode.com.au
> >>_______________________________________________
> >>grassuser mailing list
> >>grassuser at grass.itc.it
> >>http://grass.itc.it/mailman/listinfo/grassuser
> Ian Allan
> PO Box 2072
> Edithvale VIC 3196
> Mob: 0429 941 527
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060611/7b3e79ad/attachment.bin
