[GRASS-user] Help compiling under fedore 5 - "couldn't find
gdal-config"
Stephan Holl
holl at gdf-hannover.de
Sun Jun 11 15:37:20 EDT 2006
Hello Ian,
On Sun, 11 Jun 2006 18:49:31 +1000 Ian Allan <iallan at geocode.com.au>
wrote:
> Hi
> I taking the advice of messages surrounding darrel maddy's nviz
> problem (mine too), I decided to download the
> grass-6.0.2.tar.gz source file & compile it. After typing in
> CFLAGS=-g -Wall" ./configure as per the instructions I get a
> "couldn't find gdal-config" message. I have installed (and
> uninstalled and reinstalled)...
> gdal-1.3.1-2.i386 and
> gdal-bin-1.3.1-2.i386.
AFAIK you need gdal-devel or something where the needed
gdal-config-script is mostly located.
Please check with your installation if the package is available.
Then GRASS should find the needed libs.
Best
Stephan
> When I do a "locate gdal" I get reference to a number of
> files in the following directories...
> /usr/bin
> /usr/lib ( including libgdal.so.1 and libgdal.so.1.9.0)
> /usr/share/gdal
> However, in no directory is there such a file called "gdal" as is
> suggested by the error message.
> On and off over the last couple of years (for days and sometimes
> weeks at a time) I have been trying to get GRASS working. I even
> purchased a dedicated linux machine-GRASS following difficulties with
> cygwin-GRASS under windows. Still I could not get the full suite to
> work so I recently rebuilt my system using fedora core 5 in the hope
> that would work. Alas, more tears. I am at my witts end.
> P L E A S E CAN SOMEONE HELP.
> Thanks
> Ian Allan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
