[GRASS-user] Help compiling under fedore 5 - "couldn't find gdal-config"
Jachym Cepicky jachym.cepicky at centrum.cz
Sun Jun 11 05:09:32 EDT 2006
Hallo,
IMHO it has no sence to build 6.0.x from source, unless you do very well
know, why you do it. If you try "just to install GRASS" and you are
compiling it by your self, you should use 6.1.
Now to your problem
On Sun, Jun 11, 2006 at 06:49:31PM +1000, Ian Allan wrote:
> Hi
> I taking the advice of messages surrounding darrel maddy's nviz problem
> (mine too), I decided to download the    grass-6.0.2.tar.gz     source
> file & compile it. After typing in     CFLAGS=-g -Wall"
> ./configure       as per the instructions I get a    "couldn't find
> gdal-config"     message. I have installed (and uninstalled and
> reinstalled)...
the configure script does have some options, which will help the script
to find necessery programs and settings, see ./configure --help
> gdal-1.3.1-2.i386  and
> gdal-bin-1.3.1-2.i386.
gdal-bin package should have program called gdal-config. what does
which gdal-config
or
locate gdal-config
say?
you should then run ./configure with path to gdal-config, e.g.:
./configure --with-gdal=/usr/bin/gdal-config
Hope, this helps
Jachym
> When I do a     "locate gdal"      I get reference to a number of files
> in the following directories...
> /usr/bin
> /usr/lib  ( including    libgdal.so.1   and    libgdal.so.1.9.0)
> /usr/share/gdal
> However, in no directory is there such a file called "gdal" as is
> suggested by the error message.
> On and off over the last couple of years (for days and sometimes weeks
> at a time) I have been trying to get GRASS working. I even  purchased a
> dedicated linux machine-GRASS following difficulties with cygwin-GRASS
> under windows. Still I could not get the full suite to work so I
> recently rebuilt my system using fedora core 5 in the hope that would
> work. Alas, more tears. I am at my witts end.
> P L E A S E    CAN SOMEONE HELP.
> Thanks
> Ian Allan
> Ian Allan
> Director Geocode Mapping and Analysis P/L
> PO Box 2072
> Edithvale VIC 3196
> Ph: + 61 3 9773 1232   Fax: + 61 3 9773 1232
> Mob: 0429 941 527
> Email: iallan at geocode.com.au
> Web: www.geocode.com.au
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060611/079f6613/attachment.bin
