[GRASS-user] cs2cs question
Hamish
hamish_nospam at yahoo.com
Mon Jun 12 04:29:14 EDT 2006
gary wrote:
> Now I want to convert from latlong to UTM. However, I can't find the
> "init" parameter in the cs2cs documention.
cs2cs hints:
get cs2cs parms for the current location with "g.proj -j" or "g.proj -jf"
lat/lon wgs84 is:
+proj=longlat +towgs84=0.000,0.000,0.000
mind (GRASS's +proj=latlong) == (PROJ4's +proj=longlat) !!,
[shouldn't g.proj -j output in PROJ.4 style!?]
anyway it's always a good idea to reality-check output if you can.
see m.proj in GRASS 6.1 for an easy cs2cs frontend:
http://grass.ibiblio.org/grass61/manuals/html61_user/m.proj.html
Expert help for cs2cs is available from the proj mailing list.
http://proj.maptools.org
Hamish
