[GRASS-user] cs2cs question
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Jun 12 04:45:27 EDT 2006
On Mon, 12 Jun 2006, Hamish wrote:
> mind (GRASS's +proj=latlong) == (PROJ4's +proj=longlat) !!,
> [shouldn't g.proj -j output in PROJ.4 style!?]
> anyway it's always a good idea to reality-check output if you can.
Good point - that one goes back a wee while! I have changed in CVS. It
should be less confusing at least because it gives a hint as to the order
the co-ordinate pairs should be presented in.
Paul
