[GRASS-user] Re: [GRASSLIST:1098] v.net.steiner
Markus Neteler
neteler at itc.it
Wed Jun 14 09:45:44 EDT 2006
On Wed, Jun 14, 2006 at 08:52:37AM -0400, M S wrote:
> nice document! this is great stuff.
Thanks. And note that data elaboration with the current
6.1-CVS is even easier...
> The v.net.steiner seems to be a realistic functional model by using an
> existing (road) network to know what physical routes it can follow to the
> given terminals. this looks fantastic, and i cant wait to build some test
> data.
There should be a roads_net in spearfish6.0 which was recently
updated by Radim.
> is there a function (raster or vector) that would allow for building the
> network links/lines by inputting only the points without regards to an
> existing (road) network? (using something like the minimum spanning tree
> example below). This function would be great as a first cut in network
> analysis.
You could use v.hull and then v.type to make it lines or use
v.extract to only extract the boundaries, then v.type for
boundaries -> lines. (untested)
> the page below illustrates the minimum spanning tree, but if i understand
> right, just nodes are inputted. then the algorithm does at a minimum 3
> things 1) identifies clusters of sites 2) builds the links to connect the
> clusters to each other, and 3) then finds from each cluster, the nearest
> point to other clusters.
> http://www.cs.sunysb.edu/~algorith/files/minimum-spanning-tree.shtml<http://www.cs.sunysb.edu/%7Ealgorith/files/minimum-spanning-tree.shtml>
> i dont think the v.net.steiner function does what the steiner-tree function
> below illustrates, because the GRASS version uses an existing (road) network
> to realistically model the existing pathways (nice implementation!).
Kudos to Roberto Micarelli and Radim.
> This was the steiner tree example from the same site.
> http://www.cs.sunysb.edu/~algorith/files/steiner-tree.shtml
> I'm working with a Network Engineer on using GRASS to solve the network
> analysis problems. Using the NON-GRASS steiner tree (from example above)
> wont work becuase as it goes to build the links, but connects lines to
> lines, rather than given nodes. in the network implementaion this would be
> a mid-span junction, or splicing the fiber at this junction to connect the
> lines. the minimum spanning tree is more applicable. However, i suspect
> that the GRASS minimum steiner tree is the most applicable and realistic
> model/function.
It would be great to have some examples online, for
http://grass.itc.it/applications/index.php
> The GRASS minimum steiner tree is a realistic functional model that uses
> real network data in conjunction with the terminals. this seems like a
> great deployment of the steiner tree in conjunction with consideration to
> the existing network such as roads. I cant wait to have some fun with GRASS
> and give this a whirl!
> as usual, keep up the great work, and thanks to everyone who makes GRASS GIS
> be all it can be! feels great to find a GIS like this one which is fun to
> work with, and has such community invovlement. truely a great environmant
> that makes GIS fun (again for me).
Welcome!
Markus
> On 6/14/06, Markus Neteler <neteler at itc.it> wrote:
> >M S wrote on 06/14/2006 03:13 AM:
> >> The input parameter seems to be terminals. Can they be points?
> >They can be points (nodes) which have to be connected to the network.
> >You may take a look at:
> >http://mpa.itc.it/corso_dit2004/grass04_4_vector_network_neteler.pdf
> >slide 19
> >Markus
> >_______________________________________________
> >grassuser mailing list
> >grassuser at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
