[GRASS-user] [GRASSLIST:1106] Re: tin to raster dem
Laurent C. lrntct at gmail.com
Fri Jun 16 04:55:27 EDT 2006
You can try v.surf.*
2006/6/16, ivan marchesini <marchesini at unipg.it>:
> Dear all...
> I have been able to create a tin starting from the v.delaunay module and
> then manual editing the v.delaunay output exported with v.in.ascii
> (format=standard)
> now I can see, using nviz, the some filled triangles in the 3d
> space...!!!!
> now the problem:
> I would like to transfrom the tin surface in a raster surface...
> is it possible in some way!!!!
> any idea????
> Ivan Marchesini
> Department of Civil and Environmental Engineering
> University of Perugia
> Via G. Duranti 93/a
> 06125
> Perugia (Italy)
> e-mail: marchesini at unipg.it
>         ivan.marchesini at gmail.com
> tel: +39(0)755853760
> fax: +39(0)755853756
> jabber: geoivan73 at jabber.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060616/c8ea6885/attachment.html
