[GRASS-user] Update of vector table through selections in the map
    Andreas Philipp
    andreas.philipp at geo.uni-augsburg.de
    Fri Jun 16 12:02:35 EDT 2006
I've done a bit more work on that crude script v.digatt and it is posted now
to: http://grass.gdf-hannover.de/wiki/GRASS_AddOns#Vector_add-ons (last entry
at moment). The script is just tested for dbf driver, linux and just for line
and point objects.
Cheers,
Andreas
On Friday 09 June 2006 13:53, Patton, Eric wrote:
> Andreas,
> Would you consider posting you script to the WIKI for further community
> testing?
> ~ Eric.
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> To: grassuser at grass.itc.it
> Sent: 6/8/2006 5:32 PM
> Subject: Re: [GRASS-user] Update of vector table through selections in the
> map
> Hi Jonathan,
> I think I understand your task. It is relatively close to mine (quickly
> assign
> height attributes to a huge set of vector lines manually), today I
> worked
> more on that script "v.digatt" (attached if it works), it is exactly
> doing
> (if not completely buggy) what you want, if I'm right: define a
> attribute
> value (say "1" for intersections) and assign that to all points you
> click at
> in the following, then define the attribute value of "2" for
> interchanges and
> click on other  points to assign "2" to their records in the table in
> one
> step for all of them and so on. The script was tested only for lines,
> but it
> works fine for that and I tied to make it usable also for points.
> The selection is done by v.what.vect (extracting the category numbers of
> all
> objects you have clicked into a list) and the update is done with
> v.db.update
> for all collected objects (=category numbers in the list) in one step.
> Please try it and tell whether it works for you or not.
> Cheers,
> Andreas
Dr. Andreas Philipp
Institute of Geography
University of Augsburg
Universitaetsstrasse 10
D - 86135 Augsburg
Germany
Phone:   ++49/821/598-2266
Fax:     ++49/821/598-2264
Email:   andreas.philipp at geo.uni-augsburg.de
Web:     www.geo.uni-augsburg.de/lehrstuehle/phygeo
