[GRASS-user] Re: Space Oblique Mercator (SOM) and "lsat" project code
Anders Fahlén anders at agronova.se
Sun Jun 18 04:59:10 EDT 2006
I'm new to GRASS - bear with me:-)
Currently I'm working on a watershed risk
assessment task where I have Landsat TM data
spanning over a 20 year period. In order to
convert all the different Landsat projections to
one common georeferenced ground I want to import
the raster files into separate mapsets with
original projections as a first step.
One set of data is from USGS (Landsat 5 TM .tif
files) based on Space Oblique Mercator (SOM) projection.
Here is my problem: How do I correctly transform
the metadata information from the USGS Landsat 5
.hdr file using the 'lsat' projection code in
GRASS (using GRASS 6.1 cvs, WINDOWS version)?
The .hdr file received from USGS reads as follows:
  "PRODUCT =00240248-01 WRS =130/04500
ACQUISITION DATE =19921111 SATELLITE =L5
INSTRUMENT =TM10 PRODUCT TYPE =ORBIT ORIENTED
PRODUCT SIZE =FULL
SCENE
TYPE OF GEODETIC PROCESSING =SYSTEMATIC
RESAMPLING =CC RAD GAINS/BIASES =
00.00398/-0.0100 00.00964/-0.0232
00.00540/-0.0078 00.01043/-0.0193
00.00235/-0.0080 00.00000/0.00000
00.00154/-0.0040 TAPE SPANNING FLAG=1/1 START
LINE #=    1 LINES PER VOL=40096 ORIENTATION =
86.36 PROJECTION =SOM  USGS PROJECTION # =    21
USGS MAP ZONE =   100 USGS PROJECTION PARAMETERS
=   0.637813700000000D+07   0.669437999000000D-02
   0.988800000000000D+02   0.144000000000000D+04
  0.980130120103547D+08   0.129299998692014D+03
0.233000000000000D+03   0.339078914728310D-19
0.339078914728310D-19   0.339078914728310D-19
0.130000000000000D+03 EARTH ELLIPSOID
=WGS84                SEMI-MAJOR AXIS
=6378137.000 SEMI-MINOR AXIS =6356752.314 PIXEL
SIZE =30.00 PIXELS PER LINE= 6920 LINES PER
IMAGE= 5728 UL 1000636.4421E
223245.7618N  17609006.551    241587.518 UR
1015119.6129E
221736.3799N  17620546.108    423081.037 LR
1012926.4911E
204635.4062N  17791358.336    401458.922 LL
0994549.6437E
210131.2130N  17779824.490    220055.220 BANDS
PRESENT =1234567 BLOCKING FACTOR =   1 RECORD LENGTH = 6920 SUN
  ELEVATION =42 SUN AZIMUTH =142 CENTER
1004816.6229E
213945.8926N  17700964.419    321293.145  3349  2865 OFFSET=  28 REVB"
How do I correctly convert this info to the
"lsat" project code command structure in GRASS?
Some parameters are obviously known from the
header file info, e.g. Satellite Number (= 5),
Satellite Path Number (= 130), ellipsoid name (=
wgs84). How about the remaining info?
Secondly, is there a way to make on the fly
project conversions, from SOM to UTM 47, using the OGR tool?
Thanks for any hints on how to proceed.
Regards,
Anders Fahlén
Agronova
Sweden
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.1.394 / Virus Database: 268.9.0/368 - Release Date: 2006-06-16
