[GRASS-user] smoothing polygon lines
Maciek Sieczka
werchowyna at epf.pl
Mon Jun 19 12:38:07 EDT 2006
On Mon, 19 Jun 2006 11:07:23 -0400
"Jonathan Aguero" <jua130 at psu.edu> wrote:
> Maciek and list,
> Wouldn´t you get smoother lines with the prune option of v.clean?
> I've never used this option before but reading from the manual it
> says: "prune: remove vertices in threshold from lines and boundaries,
> boundary is pruned only if topology is not damaged (new intersection,
> changed attachement of centroid), first and last segment of the
> boundary is never changed".
> Playing with the threshold might acomplished what you are looking for
Not really. The smoothing we (I, at least) mean is creating a line
which goes through each original line vertex *and* through plenty
additional vertices, for the line to be smooth and close to original in
the same time. That's what splines mostly do, which Markus mentioned
in the thread.
Maciek
CIEPŁE KRAJE - CIEPŁE MORZA. Szukasz atrakcyjnego wypoczynku w przystępnej cenie, zapoznaj się z naszą ofertą.
ZAPRASZAMY
www.skarpatravel.pl
