[GRASS-user] cvs install problem
Thu Jun 22 09:51:57 EDT 2006
Francesco Mirabella wrote:
> I have a problem with cvs installation, maybe is a silly one bua I'va
> been struggling with this since yesterday...
> I've downloaded, (I am on debian testing), run the ./configure (with
> options) and than the make, but I get the following errors:
> GRASS GIS compilation log
> Started compilation: mer giu 21 12:27:42 CEST 2006
> Errors in:
> /usr/local/cvs/grass6/lib/db/sqlp
> /usr/local/cvs/grass6/db/drivers/dbf
> /usr/local/cvs/grass6/db/drivers/postgres
> /usr/local/cvs/grass6/db/drivers/ogr
> /usr/local/cvs/grass6/raster/r.mapcalc
> Finished compilation: mer giu 21 12:40:22 CEST 2006
> (In case of errors please change into the directory with error and run
> 'make')
> I did what it is said, i.e. change into directory and run make and in
> the dbf directory I get for example:
> /usr/bin/ld: cannot find -lgrass_sqlp
> collect2: ld returned 1 exit status
> make: *** [/usr/local/cvs/grass6/dist.i686-pc-linux-gnu/driver/db/dbf]
Given the previous error building the sqlp library (lib/db/sqlp), the
fact that it can't find the sqlp library isn't particularly
surprising.
The error messages from trying to build lib/db/sqlp would be more
useful.
