[GRASS-user] cvs install problem
Francesco Mirabella mirabell at unipg.it
Thu Jun 22 10:13:48 EDT 2006
Ciao Markus and Glynn,
many thanks for your reply, I tried to run make into the /sqlp and this
is what I get (only part):
btyaccpa.ske:795: error: request for member 'ss' in something not a
structure or union
btyaccpa.ske:796: error: request for member 'ss' in something not a
structure or union
btyaccpa.ske:797: error: 'YYSTYPE' undeclared (first use in this
function)
btyaccpa.ske:797: error: 'tvs' undeclared (first use in this function)
btyaccpa.ske:797: error: request for member 'vs' in something not a
structure or union
btyaccpa.ske:798: error: request for member 'ps' in something not a
structure or union
btyaccpa.ske:799: error: request for member 'ss' in something not a
structure or union
btyaccpa.ske:799: error: 'new' undeclared (first use in this function)
btyaccpa.ske:799: error: syntax error before 'Yshort'
btyaccpa.ske:800: error: request for member 'vs' in something not a
structure or union
btyaccpa.ske:800: error: syntax error before 'YYSTYPE'
btyaccpa.ske:801: error: request for member 'ps' in something not a
structure or union
btyaccpa.ske:801: error: syntax error before 'int'
btyaccpa.ske:802: error: request for member 'ss' in something not a
structure or union
btyaccpa.ske:802: error: request for member 'stacksize' in something not
a structure or union
btyaccpa.ske:803: error: request for member 'vs' in something not a
structure or union
btyaccpa.ske:803: error: request for member 'stacksize' in something not
btyaccpa.ske:804: error: request for member 'ps' in something not a
structure or union
btyaccpa.ske:804: error: request for member 'stacksize' in something not
btyaccpa.ske:805: error: request for member 'stacksize' in something not
btyaccpa.ske:806: error: 'delete' undeclared (first use in this
function)
btyaccpa.ske:806: error: syntax error before ']' token
btyaccpa.ske:807: error: syntax error before ']' token
btyaccpa.ske:808: error: syntax error before ']' token
btyaccpa.ske:809: error: request for member 'ssp' in something not a
structure or union
btyaccpa.ske:809: error: request for member 'ss' in something not a
structure or union
btyaccpa.ske:810: error: request for member 'vsp' in something not a
structure or union
btyaccpa.ske:810: error: request for member 'vs' in something not a
structure or union
btyaccpa.ske:811: error: request for member 'psp' in something not a
structure or union
btyaccpa.ske:811: error: request for member 'ps' in something not a
structure or union
btyaccpa.ske: At top level:
btyaccpa.ske:814: error: syntax error before '*' token
btyaccpa.ske:814: warning: return type defaults to 'int'
btyaccpa.ske: In function 'YYNewState':
btyaccpa.ske:815: error: 'yyparsestate' undeclared (first use in this
function)
btyaccpa.ske:815: error: 'p' undeclared (first use in this function)
btyaccpa.ske:815: error: 'new' undeclared (first use in this function)
btyaccpa.ske:815: error: syntax error before 'yyparsestate'
btyaccpa.ske:817: error: syntax error before 'Yshort'
btyaccpa.ske:818: error: syntax error before 'YYSTYPE'
btyaccpa.ske:819: error: syntax error before 'int'
btyaccpa.ske:820: error: 'YYSTYPE' undeclared (first use in this
function)
btyaccpa.ske:823: warning: control reaches end of non-void function
btyaccpa.ske:825: error: syntax error before '*' token
btyaccpa.ske: In function 'YYFreeState':
btyaccpa.ske:826: error: 'delete' undeclared (first use in this
function)
btyaccpa.ske:826: error: syntax error before ']' token
btyaccpa.ske:827: error: syntax error before ']' token
btyaccpa.ske:828: error: syntax error before ']' token
make: *** [OBJ.i686-pc-linux-gnu/y.tab.o] Error 1
francesco at terra11:/usr/local/cvs/grass6/lib/db/sqlp$
Can you help??
cheers,
Francesco
On Thu, Jun 22, 2006 at 02:51:57PM +0100, Glynn Clements wrote:
> Francesco Mirabella wrote:
> > I have a problem with cvs installation, maybe is a silly one bua I'va
> > been struggling with this since yesterday...
> > I've downloaded, (I am on debian testing), run the ./configure (with
> > options) and than the make, but I get the following errors:
> > GRASS GIS compilation log
> > Started compilation: mer giu 21 12:27:42 CEST 2006
> > Errors in:
> > /usr/local/cvs/grass6/db/drivers/dbf
> > /usr/local/cvs/grass6/db/drivers/postgres
> > /usr/local/cvs/grass6/db/drivers/ogr
> > /usr/local/cvs/grass6/raster/r.mapcalc
> > Finished compilation: mer giu 21 12:40:22 CEST 2006
> > (In case of errors please change into the directory with error and run
> > 'make')
> > I did what it is said, i.e. change into directory and run make and in
> > the dbf directory I get for example:
> > /usr/bin/ld: cannot find -lgrass_sqlp
> > collect2: ld returned 1 exit status
> > make: *** [/usr/local/cvs/grass6/dist.i686-pc-linux-gnu/driver/db/dbf]
> Given the previous error building the sqlp library (lib/db/sqlp), the
> fact that it can't find the sqlp library isn't particularly
> surprising.
> The error messages from trying to build lib/db/sqlp would be more
> useful.
> Glynn Clements <glynn at gclements.plus.com>
Francesco Mirabella,
Geologia Strutturale e Geofisica
Universita' di Perugia,
Dipartimento di Scienze della Terra,
Piazza Universita' 1, 06100 Perugia (Italy)
tel: ++39.(0)75.586.7182
fax: ++39.(0)75.586.7167
web: http://www.unipg.it/~mirabell/
