[GRASS-user] String length error in v.in.ascii
    Patton, Eric
    epatton at nrcan.gc.ca
    Thu Jun 22 11:14:14 EDT 2006
I keep receiving a string length error message when attempting to import an
ascii file in a script I'm writing, and I can't figure out what the problem
with my input is.
Here's the input file I'm using:
607126.987 5182399.765 1 Marker 21/06/06 17:59:53
606833.724 5182768.462 2 Marker 21/06/06 18:00:09
606948.631 5183269.043 3 Marker 21/06/06 18:00:14
610006.053 5182358.383 4 Marker 21/06/06 18:00:19
609820.820 5185896.693 5 Marker 21/06/06 18:00:25
607654.773 5181988.599 6 Marker 21/06/06 18:00:31
Here's my v.in.ascii call:
v.in.ascii input=vect_temp_utm_formatted output=${OUTPUT} fs=" " columns='x
double precision, y double precision, cat int, ID varchar(12), Date
varchar(10), Time varchar(10)' x=1 y=2 cat=3 --o
And error:
Maximum input row length: 50
Maximum number of columns: 6
Minimum number of columns: 6
column: 1  type: double
column: 2  type: double
column: 3  type: integer
column: 4  type: string  length: 6
column: 5  type: string  length: 8
column: 6  type: string  length: 8
ERROR: Length of column 4 (-1) is less than maximum value length (6)
Anyone have any ideas what I'm doing wrong here?
~ Eric.
