[GRASS-user] String length error in v.in.ascii
Thu Jun 22 21:07:09 EDT 2006
Eric Patton wrote:
> I keep receiving a string length error message when attempting to
> import an ascii file in a script I'm writing, and I can't figure out
> what the problem with my input is.
> Here's my v.in.ascii call:
> v.in.ascii input=vect_temp_utm_formatted output=${OUTPUT} fs=" "
> columns='x double precision, y double precision, cat int, ID
> varchar(12), Date varchar(10), Time varchar(10)' x=1 y=2 cat=3 --o
IIUC, "Date" is a reserved SQL type and can not be used as a column
name.
http://grass.ibiblio.org/grass61/manuals/html61_user/sql.html
If I change that to something else (but "_Date" is no good), your sample
data loads ok for me.
It doesn't make any difference but you can use fs=space if you like.
> And error:
> ERROR: Length of column 4 (-1) is less than maximum value length (6)
-1? strange. lib/db/dbmi_base/column.c
Hamish
