[GRASS-user] SRTM interpolation to sub-meter
    maning sambale
    emmanuel.sambale at gmail.com
    Thu Jun 22 12:41:54 EDT 2006
I have a SRTM DEM data from CGIAR (http://srtm.csi.cgiar.org/).  I'm
trying to do local sea-level rise modelling.
Suppose I want it resampled to 30 meters with elevation at a
centimeters or millimeter units.  Any thoughts on how to do this?
I believe the SRTM data are integer formats in meters.  Converting
them to floating point does not necessaily enable you to do sub-meter
elevation calculations.  Am I correct in my assumptions?
Thanks!
Maning
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |www.esambale.wikispaces.com|
| _)_/LI  |www.geocities.com/esambale/philbiodivmap/philbirds.html   |
