[GRASS-user] String length error in v.in.ascii
    Patton, Eric
    epatton at nrcan.gc.ca
    Fri Jun 23 07:23:21 EDT 2006
Thanks, you were right, the Date column was causing the problem.
~ Eric.
Eric Patton wrote:
>> I keep receiving a string length error message when attempting to
>> import an ascii file in a script I'm writing, and I can't figure out
>> what the problem with my input is.
>> Here's my v.in.ascii call:
>> v.in.ascii input=vect_temp_utm_formatted output=${OUTPUT} fs=" "
>> columns='x double precision, y double precision, cat int, ID
>> varchar(12), Date varchar(10), Time varchar(10)' x=1 y=2 cat=3 --o
Hamish:
>IIUC, "Date" is a reserved SQL type and can not be used as a column
>name.
>http://grass.ibiblio.org/grass61/manuals/html61_user/sql.html
>If I change that to something else (but "_Date" is no good), your sample
>data loads ok for me.
It doesn't make any difference but you can use fs=space if you like.
> And error:
> ERROR: Length of column 4 (-1) is less than maximum value length (6)
-1? strange. lib/db/dbmi_base/column.c
Hamish
