[GRASS-user] Makefile:22: include/Make/Platform.make: No such file or directory
David dpleydel at univ-fcomte.fr
Fri Jun 23 08:47:50 EDT 2006
Thanks to those who replied to my previous thread i.vpoints. I have been trying the CVS install and hit errors in the make process, I get similar errors using both 6.0-CVS and 6.1-CVS snapshots from http://grass.itc.it/faq/cvs_howto.html
cd /usr/local/src/grass61
tar xzf grass-6.1.cvs_src_snapshot_2006_06_18.tar.gz
export CVSROOT=:pserver:grass-guest at intevation.de:/home/grass/grassrepository
cvs login
cvs up -dP
cd grass-6.1.cvs_src_snapshot_2006_06_18
CFLAGS="-ggdb -march=k8 -Wall" ./configure \
	--with-tcltk-includes=/usr/include/tcl8.4 \
	--with-motif \
	--with-motif-includes=/usr/include/qt3 \
	--with-readline \
	--with-cxx \
	--with-odbc \
	--with-sqlite \
 	--with-freetype \
	--with-postgres-includes=/usr/include/postgresql \
	--with-ffmpeg \
	--with-ffmpeg-includes=/usr/include/ffmpeg \
	--enable-64bit \
	--with-libs=/usr/lib64 \
	--with-ffmpeg \
	--with-tiff \
	--with-blas \
	--with-lapack \
	2>&1 | tee config_log.txt
make distclean
make
Makefile:23: include/Make/Grass.make: No such file or directory
make: *** No rule to make target `include/Make/Grass.make'.  Stop.
if I use the locate command...
updatedb
locate Grass.make
/usr/local/src/grass60/grass-6.0.cvs_src_snapshot_2006_06_17/include/Make/Grass.make.in
/usr/local/src/grass61/grass-6.1.cvs_src_snapshot_2006_06_18/include/Make/Grass.make.in
so while a Grass.make.in exists the required Grass.make appears to be missing and the same applies regarding Platform.make
I'm not sure how to proceed with configuration from here.
Many thanks in advance for any hints
Dave
