[GRASS-user] i.spectral and gnuplot
    francesco
    francesco.pirotti at unipd.it
    Tue Jun 27 03:05:01 EDT 2006
Can you access gnuplot from the unix bash by typing "gnuplot"?  Probably
not since it gives that line 229 error. I don't know about Mac, but either
you have gnuplot installed as mac binary and not accessible by the unix
shell, or you have a different name.  Try installing gnuplot unix binaries.
Francesco Pirotti
At 04.18 27/06/2006, Stuart Edwards wrote:
>Francesco
>Ok -- that was straight forward (in the grand scheme of things) --
>thanks.   Now when I run i.spectral the following error is returned:
>line 229: gnuplot: command not found
>Is this a path problem on my part or something in the script?  Is
>$GNUPLOT  (from line 229) the same as GRASS_GNUPLOT (the
>environmental variable)?  Wish I knew more about this!  Thanks for
>any advice.
>Stuart
>On Jun 26, 2006, at 12:00 PM, francesco wrote:
>>Stuart,
>>I don't know about Mac's binaries, but i.spectral is actually a
>>script and it is accessible using any editor.  Check your script
>>folder in your grass distribution and remove the gnuplot check
>>strings which Glynn pointed out.
>>Cheers,
>>Francesco
>>At 15.43 26/06/2006, you wrote:
>>>Glynn, Hamish
>>>Thanks for looking into it.  Since I'm hooked on Lorenzo's binaries
>>>I'll have to wait for his next update.
>>>Stuart
>>>>>I'm trying to run i.spectral which of course requires gnuplot.  I
>>>>>have gnuplot 4 installed (via fink) but i.spectral can't see it and
>>>>>asks for it to be installed.  I made GRASS_GNUPLOT = /sw/bin but
>>>>>that
>>>>>didn't help.  I'm running 6.1cvs on OSX 10.4.6.  Any suggestions on
>>>>>how to make gnuplot visible to i.spectral would be much
>>>>>appreciated.
>>>>There is a gratuitous check for whether gnuplot is in the path:
>>>>         #check if present
>>>>         if [ ! -x "`which gnuplot`" ] ; then
>>>>             echo "$PROG: gnuplot required, please install first"
>>>>2>&1
>>>>             exit 1
>>>>         fi
>>>>Remove that check from the i.spectral script. It actully uses
>>>>$GRASS_GNUPLOT to invoke it.
>>>>Glynn Clements <glynn at gclements.plus.com>
>>>>_______________________________________________
>>>>grassuser mailing list
>>>>grassuser at grass.itc.it
>>>>http://grass.itc.it/mailman/listinfo/grassuser
