[GRASS-user] Newbie adding additional modules?
Barry Baker bbaker at TNC.ORG
Thu Jun 29 20:44:20 EDT 2006
Thank you Hamish, David and Nagesh for your prompt suggestions on how to fix
my problem with outputting Netcdf files.
Best,
Barry
On 6/26/06 10:20 PM, "Hamish" <hamish_nospam at yahoo.com> wrote:
> Barry Baker wrote:
>> It has been nearly 16 years since I used Grass and now coming back.
>> I have GRASS up and running on my Mac PowerBook G4 with OS X 10.4.6
>> Now I am trying to install the r.out.netcdf module and am at a loss as
>> to how to go about it.  Any help would be appreciated.
> Unless r.out.netcdf is packaged for the new GRASS 6.1 Extension Manager
> (GEM), and I'm pretty sure it isn't, you will need the full grass source
> code to compile it.
> after ./configure, make of source code,
> mkdir raster/r.out.netcdf/
> cd raster/r.out.netcdf/
> cp r.out.netcdf_source_files/* .
> make
> alternatively and probably simpler, use r.out.gdal for NetCDF output:
> GRASS> gdalinfo --formats
>   GMT (rw): GMT NetCDF Grid Format
>   netCDF (ro): network Common Data Format
> In my old version of GDAL, the GMT version is only one which it can
> write to. I'm not sure what the latest version can do.
> http://www.gdal.org/formats_list.html
> another indirect way is to use r.out.mat to make a Matlab array and
> to save a NetCDF file from there. (r.out.mat is untested on big-endian
> AFAIK, if that doesn't work use raw r.out.bin -> Matlab)
> If you are looking to send output to GMT, there are other options &
> scripts that can be used. see r.out.gmt on the wiki add-ons page and:
>  http://169.237.35.250/~dylan/grass_user_group/#GMT_and_GRASS-overview
> Hamish
_________________________
Barry Baker, Ph.D.
Global Climate Change Initiative
The Nature Conservancy
2424 Spruce St., Suite 100
Boulder, CO 80302
Tel: (303)-541-0322
Fax: (303)-449-4328
http://nature.org/tncscience/scientists/misc/baker.html
