[GRASSLIST:10641] Re: is there netcdf support in GRASS??
Matthew Perry perrygeo at gmail.com
Wed Mar 1 01:17:34 EST 2006
Vishal,
  GDAL has limited support for the netcdf format
(http://www.gdal.org/frmt_various.html#netCDF). You have to compile
GDAL explicitly with this option since it's not the default. If you've
got his setup, you might be able to use r.in.gdal to import to GRASS.
matt
On 2/28/06, Vishal Mehta <vishalm1975 at gmail.com> wrote:
> Good people,
> i'm trying to figure out if GRASS can import netcdf format files.
> Has anyone out there used netcdf files for modeling in GRASS?
> thanks,
> vishal
Matt Perry
http://www.perrygeo.net
