[GRASSLIST:10642] Re: joining attribute tables of points and
areas???
Hamish
hamish_nospam at yahoo.com
Wed Mar 1 02:37:54 EST 2006
> Given are two vector maps (one with POINTS and one with AREAS).
> The result should be a vector map (POINTS) containing the attributes
> of the original points and of the areas in that the points lie in.
> <v.overlay> obviously doesn't work here. I also tried <v.select>, but
> that's also not woorking, since this function doesn't join the attribute
> tables.
use v.distance.
see example 2 in the v.distance help page:
http://grass.ibiblio.org/grass61/manuals/html61_user/v.distance.html
sorry for the long(!) delay in response. maybe it helps someone
searching the archives..
Hamish
