[GRASSLIST:10668] Re: r.fillnulls
Markus Neteler neteler at itc.it
Wed Mar 1 17:03:45 EST 2006
On Sat, Feb 25, 2006 at 09:46:03AM +0100, Maciek Sieczka wrote:
> On Fri, 24 Feb 2006 16:28:02 +0000
> "giglio.antonio at katamail.com" <giglio.antonio at katamail.com> wrote:
> > Hi, i used r.in.srtm for building a DEM. I have joined images (1°x1°
> > squares) using r.patch, and now i'm trying to fill "no data" holes in
> > the map i obtained. I think to use r.fillnulls, but have the
> > following error:
> > r.fillnulls input=input_name output=srilanka.dem tension=40.
> > smooth=0.1 Using tmp file r_fillnulls_3464
> > Locating and isolating NULL areas...
> > GRASS_INFO_ERROR(3474,1): invalid ellipsoid i
> > \a in file PROJ_INFO in PERMANENT
> Please post what Grass version you are using, g.proj -p output and the
> contents of your_location/PERMANENT/PROJ_INFO file. Maybe it will help
> to indicate the problem.
As the message says: an ellipsoid "i" doesn't exist.
This needs to be defined properly.
Markus
