[GRASSLIST:10721] Re: (no subject)
Maciek Sieczka werchowyna at epf.pl
Fri Mar 3 12:14:11 EST 2006
On Fri, 3 Mar 2006 14:35:07 +0100
Klecskó Bernadett <bernadett.klecsko at geohidroterv.hu> wrote:
> Hi.
> I have "some"  questions about GRASS 6.1.:
> 1. I made a raster file which is a surface and I made a vector file,
> which contain the datapoints of this surface. I woluld like to add
> some new points for the database with  command v.digit, but it
> couldn't add value of point of surface, just added coordinates and
> categories.How can I make a database with v.digit, which contain x,y
> coordinates and  value of surface?
Add necessary columns to your databse. Refer to db.execute
and v.db.addcol.
> 2.how can I print from NVIZ?
Export image and print it.
> 3.how can I joint the surface, vector lines and volumes in NVIZ with
> coordinates?
Could you elaborate on this? Or maybe somebody else gets it better what
you mean. Sorry :).
Maciek
Szukasz solidnej firmy reklamowej? Dobrze trafiłeś! Zapraszamy do nas!
http://www.artkomp.pl , lub zadzwoń: (0-33) 816-86-01
