[GRASSLIST:10723] Re: v.in.ascii failing on large files?
Jose Gomez-Dans
jgomezdans at gmail.com
Fri Mar 3 12:50:05 EST 2006
Hi!
On 03/03/06, Markus Neteler <neteler at itc.it> wrote:
> Note that there is the
> -b Do not build topology in points mode
> flag. Helena and others imported some 500M points like this. v.surf.rst
> is under modification to support disabled topology (maybe it does
> already, I didn't try recently).
> If you operate with points only (like LIDAR), this is the way to
> overcome the problem.
This is interesting, as I'm still using GRASS5 for {v|s}.surf.rst and large
datasets. Can anyone confirm that using the -b option reads up a large
number of points without problems, and that these can be used with
v.surf.rst?
Many thanks!
Jose
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060303/d7cbc8fe/attachment.html
