[GRASSLIST:10754] Re: GRASS topographic position functionality
beyond r.param.scale?
Trevor Wiens
twiens at interbaun.com
Mon Mar 6 00:12:46 EST 2006
On Sat, 4 Mar 2006 20:14:44 -0800
Graham Watt-Gremm <sunyata at uvic.ca> wrote:
> Hi Ian (and/or GRASS user list),
> Did you ever get a response to this query, or develop something
> yourself? I would like to get at the (unidentified Arc/Info) slope
> position algorithm used by Wimberly and Spies (2001, Ecology 82(5):
> 1443-1459), where topographic position grades from 0 at valley bottom
> to 100 at ridge top. I am thinking along the lines of using some of
> the output from r.flow (flowline segments in each cell a function of
> transformed distance from valley bottom), though I have no experience
> with this module. Does anyone have any suggestions?
> Cheers and thanks,
> Graham Watt-Gremm
> Rocky Mountain Repeat Photography Project
> School of Environmental Studies
> University of Victoria
> sunyata at uvic dot ca
> [GRASSLIST:1410] GRASS topographic position functionality beyond
> r.param.scale?
> Ian Allan iallan at geocode.com.au
> Mon, 06 Oct 2003 12:29:41 +1000
> Previous message: [GRASSLIST:1408] Finished
> Next message: [GRASSLIST:1411] compiling GRASS with tcl8.4
> Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
> Hi
> Can anyone suggest a technique for determining topographic position that
> would provide more information than r.param.scale? In particular, I'm
> interested in mapping upper slopes, mid slopes and lower slopes.
> Many thanks
> Ian Allan
Another option to consider is the topographic convergence index
calculated by r.terraflow (if you have C++ support included).
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
