[GRASSLIST:10759] Re: draw gps co-ordinates with a varying circle around them
C. H. Roosevelt
chr at bu.edu
Mon Mar 6 02:42:00 EST 2006
Hi Michael,
On the subject of d.vect.thematic and drawing circles of varying size
around points [perhaps not the best place to jump into this
question], is there any way to have d.vect.thematic display points
graduated according to exact values (e.g., diameters from an
attribute column) rather than according to intervals, std. devs.,
etc.? A while back Hamish wrote this option into ps.map and I find it
extremely useful.
Chris
On Mar 6, 2006, at 9:05 AM, Michael Barton wrote:
> You can also use the thematic mapper (d.vect.thematic)
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Hamish <hamish_nospam at yahoo.com>
>> Date: Mon, 6 Mar 2006 15:05:58 +1300
>> To: <dylan.beaudette at gmail.com>
>> Cc: <phm4 at kent.ac.uk>, <GRASSLIST at baylor.edu>
>> Subject: [GRASSLIST:10746] Re: draw gps co-ordinates with a
>> varying circle
>> around them
>>>> I hope I explain my problem properly. I have managed, with your
>>>> help, to visualise my gps data with v.neigbors, where v.neigbors
>>>> lets me specify the size of the neigborhood diameter and then
>>>> counts
>>>> how many gps points fall within each neigborhood.
>>>> What I like to do now is to visualise gps data which has long and
>>>> lat, plus a value for the size of the neigborhood around each
>>>> long -
>>>> lat co-ordinate, e.g.:
>>>> 51.298895 | 1.071705 | 0.1
>>>> I don't want grass to count the frequency of gps co-ordinates which
>>>> fall into the neigborhood, as all of them have already been
>>>> eliminated from the data. So all I want grass to do essentially is
>>>> to visualise gps co-ordinates with varying circles around them.
>>>> Thank you for pointing me into the right direction.
>>>> Cheers,
>>>> Phil
>>> Give d.vect.thematic a try.
>> for bubble plots also try 'd.vect.chart ctype=pie' with only one data
>> column, size column.
>> or try 'v.buffer bufcol=' (sometimes buggy)
>> Hamish
C. H. Roosevelt
Archaeology Department
Boston University
675 Commonwealth Avenue
Boston, MA, 02215-1406
Tel: (617) 358-1652 (direct)
Tel: (617) 353-3415 (main office)
Fax: (617) 353-6800
E-mail: chr at bu.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060306/645411fd/attachment.html
