[GRASSLIST:10760] Re: draw gps co-ordinates with a varying circle around them
Michael Barton michael.barton at asu.edu
Mon Mar 6 02:44:47 EST 2006
You can use the custom breaks option. This is not exactly what you are
asking about, but it might be close enough.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Mon, 6 Mar 2006 09:42:00 +0200
To: Multiple recipients of list <GRASSLIST at baylor.edu>
Cc: Michael Barton <michael.barton at asu.edu>
Subject: Re: [GRASSLIST:10756] Re: draw gps co-ordinates with a varying
circle around them
Hi Michael,
On the subject of d.vect.thematic and drawing circles of varying size around
points [perhaps not the best place to jump into this question], is there any
way to have d.vect.thematic display points graduated according to exact
values (e.g., diameters from an attribute column) rather than according to
intervals, std. devs., etc.? A while back Hamish wrote this option into
ps.map and I find it extremely useful.
Chris
On Mar 6, 2006, at 9:05 AM, Michael Barton wrote:
> You can also use the thematic mapper (d.vect.thematic)
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
>> From: Hamish <hamish_nospam at yahoo.com>
>> Date: Mon, 6 Mar 2006 15:05:58 +1300
>> To: <dylan.beaudette at gmail.com>
>> Cc: <phm4 at kent.ac.uk>, <GRASSLIST at baylor.edu>
>> Subject: [GRASSLIST:10746] Re: draw gps co-ordinates with a varying circle
>> around them
>>>> I hope I explain my problem properly. I have managed, with your
>>>> help, to visualise my gps data with v.neigbors, where v.neigbors
>>>> lets me specify the size of the neigborhood diameter and then counts
>>>> how many gps points fall within each neigborhood.
>>>> What I like to do now is to visualise gps data which has long and
>>>> lat, plus a value for the size of the neigborhood around each long -
>>>> lat co-ordinate, e.g.:
>>>> 51.298895 | 1.071705 | 0.1
>>>> I don't want grass to count the frequency of gps co-ordinates which
>>>> fall into the neigborhood, as all of them have already been
>>>> eliminated from the data. So all I want grass to do essentially is
>>>> to visualise gps co-ordinates with varying circles around them.
>>>> Thank you for pointing me into the right direction.
>>>> Cheers,
>>>> Phil
>>> Give d.vect.thematic a try.
>> for bubble plots also try 'd.vect.chart ctype=pie' with only one data
>> column, size column.
>> or try 'v.buffer bufcol='  (sometimes buggy)
>> Hamish
C. H. Roosevelt
Archaeology Department
Boston University
675 Commonwealth Avenue
Boston, MA, 02215-1406
Tel: (617) 358-1652 (direct)
Tel: (617) 353-3415 (main office)
Fax: (617) 353-6800
E-mail: chr at bu.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060306/231ba9ce/attachment.html
