[GRASSLIST:10767] Re: issues with
grass-6.1.cvs-i686-pc-linux-gnu-01_03_2006: nviz does not work
Maciek Sieczka
werchowyna at epf.pl
Mon Mar 6 12:07:44 EST 2006
On Sun, 5 Mar 2006 23:11:19 -0300
"Carlos \"Guâno\" Grohmann" <carlos.grohmann at gmail.com> wrote:
> Also considr upgrading into Breezy (at least). DebianGis packages are
> most suitable for Debian Unstable/Testing or Ubuntu Dapper Drake 6.04,
> but you can expect that not everything will work cleanly.
> If you want to run GRASS+QGIS, I suggest you install stuff like
> fftw-2.15, geos, tcl/tk8.3 etc from the repositories via
> apt-get/synaptic and then compile gdal, grass and qgis from source.
> There is a dependency problem with libgeosc2a, whith will prevent from
> installing libgrass, libgdal-grass and qgis-grass-plugins.
> This may sound trick, but itś what I did;
> 1 - install GDAL via synaptic
> 2 - compile GRASS from source
> 3 - remove GDAL via synaptic
> 4 - compile GDAL from source (use --with-grass=path-to-your-install)
> 5 - compile GRASS again with your new GDAL
> 6 - compile QGIS (use --with-grass=path-to-your-install).
This is not the optimal solution. Most straightforward is to use
gdal-grass plugin - no need rebuild each one against each other.
However, to use the current gdal-grass plugin version you'll need at
least Gdal 1.3.1. Please read the WIKI
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassQgisGdalOgrPlugin
Main WIKI page:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/WebHome
Many usefull hints.
Maciek
http://www.visanen.pl/ - Zapakujemy wszystko!
Produkcja i dystrybucja torby foliowe, papierowe, reklamówki, opakowania kartonowe, ekskluzywne pudełka
