[GRASSLIST:10789] problem upgrading FWTools to handle ECW
Roy Sanderson
R.A.Sanderson at newcastle.ac.uk
Tue Mar 7 05:01:26 EST 2006
Hello
I'm trying to upgrade the version of FWTools that is used with GRASS, so
that r.in.gdal can handle ECW format files. Until now I have been using
FWTools-0.9.4 without problems, but am now trying FWTools-1.0.0a7 to get
the ECW support. However, on running the GRASS configure script, it fails
on gdal, as it gives an error on the GDALOpen test. The call to configure is:
./configure --without-postgres --without-odbc --without-fftw
--with-gdal=/usr/local/FWTools-1.0.0a7/bin_safe/gdal-config
--with-proj-includes=/usr/local/FWTools-1.0.0a7/include
--with-proj-libs=/usr/local/FWTools-1.0.0a7/lib
and the error message is:
checking for gdal-config... /usr/local/FWTools-1.0.0a7/bin_safe/gdal-config
checking for GDALOpen... no
configure: error: *** Unable to locate GDAL library
I've set LD_LIBRARY_PATH to point to /usr/local/FWTools-1.0.0a7/lib and
have run ldconfig with ld.so.conf modified to point to the above. Running
GRASS 6.0.2 on Redhat 7.3. The gdal_translate program lists ECW as an
accepted format in FWTools-1.0.0a7, but not on the older 0.9.4 version that
I had been using.
Many thanks for any help.
Best wishes
Roy
Roy Sanderson
Institute for Research on Environment and Sustainability
Devonshire Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 246 4835
Fax: +44 191 246 4999
http://www.ncl.ac.uk/environment/
r.a.sanderson at newcastle.ac.uk
