[GRASSLIST:10798] Re: awk not found on Mac osx, Repost
Dave Kent
dkent at sasktel.net
Tue Mar 7 18:43:09 EST 2006
Thanks Michael:
I get:
GRASS 6.1.cvs (SaskNad83UTM) > $PATH
tcsh: /usr/X11R6/bin:/usr/local/bin:/usr/local/grasslib/bin:/
Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/
bin:/Applicati
ons/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/scripts:/
usr/bin:/bin:/usr/bin:/bin:/usr/sbin:/sbin: Command not found.
Looks like /usr/bin is present. In fact it is in twice. Could this
be a problem?
What does "command not found" indicate?
Dave
On Mar 7, 2006, at 11:34 AM, Michael Barton wrote:
> It sounds like a path problem. That is, it sounds like /usr/bin is
> not in your default path, or at least the one active within the
> GRASS environment. From the GRASS command line, type
> $PATH
> (followed by return) and see if /usr/bin is in the list of folders.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> From: Dave Kent <dkent at sasktel.net>
> Date: Mon, 06 Mar 2006 23:11:40 -0600
> To: <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:10784] awk not found on Mac osx, Repost
> I posted this some time ago. Markus responded with a change which
> has been incorporated into CVS code.
> However, this hasn't helped things for me as I still am getting a
> problem with "awk required"
> I am using 6.1 CVS with Lorenzo's binaries (06 March 06 ) on a
> macintosh OS 10.4.
> When I try to add a database column I get:
> v.db.addcol map=CondieHead layer=1 'columns=Elev varchar(10)'
> csh: /sw/bin/init.csh: No such file or directory.
> : awk required, please install awk/gawk first
> This suggests awk is absent. When I invoke awk from the grass
> command line, I get:
> GRASS 6.1.cvs (SaskNad83UTM) > awk
> Usage: awk [-f programfile | 'program'] [-Ffieldsep] [-v var=value]
> [files]
> This suggests that awk is present as it lists the help line.
> I have not installed awk/gawk. It is present in the Mac OSX
> installation at /usr/bin/awk
> Are there some environmental or other settings I need to set so
> that Grass sees awk?
> This also happens when opening a QGIS connection from the display
> manager.
> Thanks
> Dave
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060307/5db89852/attachment.html
