[GRASSLIST:10817] Re: Error in startup script: couldn't execute "ps.map": no such file or directory
Nagesh Bhatkar bnagesh at nio.org
Wed Mar 8 05:37:22 EST 2006
Hello Ravi,
I installed grass-6.0.0 from source grass-6.0.0.tar.gz and not using rpm.
After i got errors i tried the following:
I copied the lib directory from grass-6.0.1 into grass-6.0.0  and then
compiled it successful.
It worked fine with no errors.
But this definately isnt the solution.
May I know which RPMs are you referring to?
Nagesh Bhatkar
RAVI KUMAR wrote:
> Hi Nagesh,
> it is loading of RPMs that may not be ok..
> Pl check.
> Ravi Kumar
> */Nagesh Bhatkar <bnagesh at nio.org>/* wrote:
>     Dear GRASS users,
>     I Installed grass-6.0.0 on mandriva 2006.
>     On running grass , I get the following error
>     directory
>     while executing
>     "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
>     "DmPrint::init"
>     (procedure "main" line 32)
>     invoked from within
>     "main $argc $argv"
>     (file "/home/bnagesh/grass-6.0.0/etc/dm/d.m.tcl" line 894)
>     After realising that ps.map isnt getting compiled , i tried
>     compiling it
>     manually
>     using make command in the ps directory.
>     I got the following error:
>     /usr/bin/ld: cannot find -lgrass_I
>     collect2: ld returned 1 exit status
>     make[1]: ***
>     [/home/bnagesh/grass-6.0.0/dist.i686-pc-linux-gnu/bin/ps.map] Error 1
>     make[1]: Leaving directory `/home/bnagesh/grass-6.0.0/ps/ps.map'
>     Later i realised that in ~/grass-6.0.0/lib, libgrass_I.so ,
>     libgrass_Iortho.so, isnt created.
>     Can anyone help me get rid of these errors.
>     Has anybody compiled grass-6.0.0 on mandriva 2006 successfully?
>     Kindly help
>     Nagesh Bhatkar
>     Project Assistant III
>     National Institute of Oceanography
>     India - Goa
> Yahoo! Mail
> Use Photomail
> <http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=38867/*http://photomail.mail.yahoo.com>
> to share photos without annoying attachments.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060308/7687f965/attachment.html
