[GRASSLIST:10832] Re: v.in.ascii error
    Hamish
    hamish_nospam at yahoo.com
    Wed Mar  8 17:32:44 EST 2006
> I think your command should look something like this:
> v.in.ascii input=/home/pierluigi/Desktop/zinc output=zinc format=point
> fs=| columns='x double, y double, ppm double' x=1 y=2
>From the command line yes, but quote the pipe (|).
so if you try:
G6> v.in.ascii input=/home/pierluigi/Desktop/zinc output=zinc \
  format=point fs='|' columns='x double, y double, ppm double' x=1 y=2
It should be ok. The shell needs to be protected from special chars
(pipe is the redirect command) and also needs to be told that multiword
answers belong with a single option. The GUI and SQL don't need to be
protected as such.
If you are running from the GUI, you should not quote the pipe (|) or
the column names/types:
> SQL parser error in statement:
> create table zinc ( cat integer, 'x double precision, y double
>  precision, ppm double precision' )
The ' before the x and after precision should not be there. You are
quoting too much.
> I realised that the gui of v.in.ascii usually puts together the
> command incorrectly, so I always use the cli to import ascii files.
How so? If it is broken we can fix it, but I don't think it is broken.
Hamish
