[GRASSLIST:10835] Re: Bus Error in g.remove
William Kyngesburye
woklist at kyngchaos.com
Wed Mar 8 19:40:04 EST 2006
This is probably the same bug Michael Barton reported yesterday
(#4152) and I reported last August (#3585). Specifically, when GRASS
is built on OS 10.3 Panther (GCC 3.3), and GDAL has Postgres
support. It's probably happening for you in Tiger because Lorenzo
builds with Panther compatibility - either on Panther, or on Tiger
using the Panther SDK. A Tiger-only build (GCC 4) is unaffected.
It's a strange bug - I can build GRASS with GDAL without Postgres
support, then update GDAL to include Postgres support and it still
works. It's only when GDAL has Postgres support *at the time GRASS
is built*. I've tried various combinations of static and dynamic
Postgres libraries (and the exact same ones used for Postgres support
in GRASS) and other options in GDAL and GRASS and GRASS with/without
its own Postgres support.
On Mar 8, 2006, at 6:14 PM, Dave Kent wrote:
> I am using Grass 6.1CVS on Macintosh with the most recent Macintosh
> binaries.
> g.remove gives the following error.
> child killed: bus error
> while executing
> "exec -- $cmd --tcltk"
> (procedure "execute" line 4)
> invoked from within
> "execute g.remove "
> (menu invoke)
> This started quite suddenly, possibly consistent with messing with
> AWK post I had yesterday.
> I get the same error with g.copy, g.rename but not g.list
> I have reinstalled the binaries and the application.
> There was a not too similar message in the archives which relates
> to the environmental variable file being corrupted. I cannot find
> this file and haven't tried removing it.
> I am at a bit of a loss on what to do.
> Any help would be appreciated.
> Thanks
> Dave
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
