[GRASSLIST:10837] Re: Bus Error in g.remove
Dave Kent
dkent at sasktel.net
Wed Mar 8 22:04:54 EST 2006
Thanks for the insight. I went back to the Nov 05 binaries and
Janurary CVS version and things work. That will be fine for now. I
guess learning how to build wouldn't be a bad thing.
Thanks for your help.
Dave
On Mar 8, 2006, at 6:40 PM, William Kyngesburye wrote:
> This is probably the same bug Michael Barton reported yesterday
> (#4152) and I reported last August (#3585). Specifically, when
> GRASS is built on OS 10.3 Panther (GCC 3.3), and GDAL has Postgres
> support. It's probably happening for you in Tiger because Lorenzo
> builds with Panther compatibility - either on Panther, or on Tiger
> using the Panther SDK. A Tiger-only build (GCC 4) is unaffected.
> It's a strange bug - I can build GRASS with GDAL without Postgres
> support, then update GDAL to include Postgres support and it still
> works. It's only when GDAL has Postgres support *at the time GRASS
> is built*. I've tried various combinations of static and dynamic
> Postgres libraries (and the exact same ones used for Postgres
> support in GRASS) and other options in GDAL and GRASS and GRASS
> with/without its own Postgres support.
> On Mar 8, 2006, at 6:14 PM, Dave Kent wrote:
>> I am using Grass 6.1CVS on Macintosh with the most recent
>> Macintosh binaries.
>> g.remove gives the following error.
>> child killed: bus error
>> while executing
>> "exec -- $cmd --tcltk"
>> (procedure "execute" line 4)
>> invoked from within
>> "execute g.remove "
>> (menu invoke)
>> This started quite suddenly, possibly consistent with messing with
>> AWK post I had yesterday.
>> I get the same error with g.copy, g.rename but not g.list
>> I have reinstalled the binaries and the application.
>> There was a not too similar message in the archives which relates
>> to the environmental variable file being corrupted. I cannot find
>> this file and haven't tried removing it.
>> I am at a bit of a loss on what to do.
>> Any help would be appreciated.
>> Thanks
>> Dave
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin] You think you have problems? What are you supposed to do
> if you ARE a maniacally depressed robot? No, don't try and answer,
> I'm 50,000 times more intelligent than you and even I don't know
> the answer...
> - HitchHiker's Guide to the Galaxy
