[GRASSLIST:10850] Re: Problem with r.contour
Michael Rensing
michael.rensing at shaw.ca
Thu Mar 9 10:01:59 EST 2006
I've watched the memory use climb while the CPU cycles drop to 1 or 2
percent. Presumably it does into a swap frenzy. The same thing happens
whether r.contour finishes successfully or not.
How would I measure the size of the areas? I'll look for the area sizes
later today. Gotta go to work now...
Michael
Hamish wrote:
>> I'm using r.contour to extract contours from a DEM raster. Everything
>> works fine until I try to do a region over a certain size. Then
>> r.contour just quits spontaneously. If I run it from the command line,
>> all it says is "Killed".
>> I'm sure it's a memory/size problem, and the routine take a long time,
>> but I just want to set it to work and wait for the response. Is there
>> anyone who understands r.contour enough who would care to do some
>> debugging? I'd be happy to work together on this.
> try running "top" in a terminal window along side and watch the memory
> grow.
> How big is too big?
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060309/89737663/attachment.html
