[GRASSLIST:10861] Re: issues with grass-6.1.cvs-i686-pc-linux-gnu-01_03_2006: nviz does not work
Vishal Mehta
vishalm1975 at gmail.com
Fri Mar 10 01:20:07 EST 2006
> Hi all,
I upgraded from Hoary to Breezy, then installed grass 6.0.1 which is in the
repositoryy, so is qgis 0.6.
results:
1. Grass is working fine with NVIZ also working fine;
2. QGIS does not recognize GRASS rasters probably because of what you all
wrote that it depends on ligdal1-grass, because on upgrading, libgdal1 got
replaced by libgdal2;
so, i guess i'll try going the gdal compile; gdal-grass compile way that you
suggest here.
A related issue: i'm trying to bring in netcdf format files with he help of
gdal_translate and r.in.gdal.
I get an error as follows:
GRASS 6.0.1 (test2):~ > r.in.gdal -oe
input=/home/vishal/NCEPdata/lhtfl.sfc.gauss.2004.nc output=lhfttrial[1]+
Done d.m
Segmentation fault
Also, i'm not sure if the GDAL version i have supports netcdf:
This is the GDAL i have, satraight from the Breezy repository:
GDAL 1.2.6.0, released 2005/03/13
So i'm wondering that to have both the grass-qgis plugin, and netcdf
support, i need to compile gdal with both??
thanks much!
cheers,
vishal
On 3/7/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > On Mon, 6 Mar 2006 17:23:57 -0300
> > "Carlos \"Guâno\" Grohmann" < carlos.grohmann at gmail.com> wrote:
> > > one can't install qgis-grass-plugin because it depends on
> > > libgdal1-grass.
> > > libgdal1-grass:
> > > Depends: libgdal1c2 (>=1.2.6) but it is not installable
> > > why? because there is no package called ligdal1c2, but there is
> > > ligdal1c2a....
> > Carlos,
> > Build gdal-grass from source then. Fetch it from here:
> > http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
> > I've been using it. No problems. IMHO it is easier and safer to:
> > 1. build Gdal from source
> > 2. build Grass from source
> > 3. build Gdal-Grass plugin from source
> > 4. build Qgis from source
> > (3 and 4 order doesn't really matter)
> > Than to proceed as you suggest:
> > > 1 - install GDAL via synaptic
> > > 2 - compile GRASS from source
> > > 3 - remove GDAL via synaptic
> > > 4 - compile GDAL from source (use --with-grass=path-to-your-install)
> > > 5 - compile GRASS again with your new GDAL
> > > 6 - compile QGIS (use --with-grass=path-to-your-install).
> > I also recommend using checkinstall->dpkg instaed of plain "make
> > install". Using custom debs is good better software management and
> > sanity.
> > Note: I have just noticed a newer gdal-grass plugin version of March
> > 1st:
> > http://www.gdal.org/dl/gdal-grass-1.3.1.2.tar.gz
> > Anybody knows if it is recommended? 1.3.1.1 is OK for me by now. Does
> > anybody know what are the changes?
> > Maciek
> > http://www.visanen.pl/ - Zapakujemy wszystko!
> > Produkcja i dystrybucja torby foliowe, papierowe, reklamówki, opakowania
> > kartonowe, ekskluzywne pudełka
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060310/1a6bef19/attachment.html
