[GRASSLIST:10867] Re: issues with grass-6.1.cvs-i686-pc-linux-gnu-01_03_2006: nviz does not work
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Fri Mar 10 09:26:31 EST 2006
I just get this from DebianGis today:
>Schuyler Erle <schuyler at nocat.net> to me
> More options 11:18 am (6 minutes ago)
>* On 3-Mar-2006 at 2:41PM PST, Carlos Guâno Grohmann said:
> OK. will there be new packages for libgrass-gdal and qgis-plugins-grass soon?
>There are Ubuntu packages for all that stuff here:
http://freemap.in/~sderle/deb/
>Sorry I didn't see this thread sooner. I need to see what I can do to
try it.
On 3/10/06, Vishal Mehta <vishalm1975 at gmail.com> wrote:
> > Hi all,
> I upgraded from Hoary to Breezy, then installed grass 6.0.1 which is in the
> repositoryy, so is qgis 0.6.
> results:
> 1. Grass is working fine with NVIZ also working fine;
> 2. QGIS does not recognize GRASS rasters probably because of what you all
> wrote that it depends on ligdal1-grass, because on upgrading, libgdal1 got
> replaced by libgdal2;
> so, i guess i'll try going the gdal compile; gdal-grass compile way that you
> suggest here.
> A related issue: i'm trying to bring in netcdf format files with he help of
> gdal_translate and r.in.gdal.
> I get an error as follows:
> GRASS 6.0.1 (test2):~ > r.in.gdal -oe
> input=/home/vishal/NCEPdata/lhtfl.sfc.gauss.2004.nc
> output=lhfttrial[1]+ Done d.m
> Segmentation fault
> Also, i'm not sure if the GDAL version i have supports netcdf:
> This is the GDAL i have, satraight from the Breezy repository:
> GDAL 1.2.6.0, released 2005/03/13
> So i'm wondering that to have both the grass-qgis plugin, and netcdf
> support, i need to compile gdal with both??
> thanks much!
> cheers,
> vishal
> > On 3/7/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > > On Mon, 6 Mar 2006 17:23:57 -0300
> > > "Carlos \"Guâno\" Grohmann" < carlos.grohmann at gmail.com> wrote:
> > > > one can't install qgis-grass-plugin because it depends on
> > > > libgdal1-grass.
> > > > libgdal1-grass:
> > > > Depends: libgdal1c2 (>=1.2.6) but it is not installable
> > > > why? because there is no package called ligdal1c2, but there is
> > > > ligdal1c2a....
> > > Carlos,
> > > Build gdal-grass from source then. Fetch it from here:
> > > http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
> > > I've been using it. No problems. IMHO it is easier and safer to:
> > > 1. build Gdal from source
> > > 2. build Grass from source
> > > 3. build Gdal-Grass plugin from source
> > > 4. build Qgis from source
> > > (3 and 4 order doesn't really matter)
> > > Than to proceed as you suggest:
> > > > 1 - install GDAL via synaptic
> > > > 2 - compile GRASS from source
> > > > 3 - remove GDAL via synaptic
> > > > 4 - compile GDAL from source (use
> --with-grass=path-to-your-install)
> > > > 5 - compile GRASS again with your new GDAL
> > > > 6 - compile QGIS (use
> --with-grass=path-to-your-install).
> > > I also recommend using checkinstall->dpkg instaed of plain "make
> > > install". Using custom debs is good better software management and
> > > sanity.
> > > Note: I have just noticed a newer gdal-grass plugin version of March
> > > 1st:
> > > http://www.gdal.org/dl/gdal-grass-1.3.1.2.tar.gz
> > > Anybody knows if it is recommended? 1.3.1.1 is OK for me by now. Does
> > > anybody know what are the changes?
> > > Maciek
> > > http://www.visanen.pl/ - Zapakujemy wszystko!
> > > Produkcja i dystrybucja torby foliowe, papierowe, reklamówki, opakowania
> kartonowe, ekskluzywne pudełka
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
