[GRASSLIST:72] Re: r.water.outlet - catchment
Cannata, Massimiliano
massimiliano.cannata at supsi.ch
Tue Mar 14 04:02:17 EST 2006
Maybe it is obvious, but did you choose a cell in the
river?
I mean, was the flow accumulation different from 1?
The chosen point should reside into a pixel with high flow
accumulation values (many cell drain into it and the basin
can be extracted).
I succesfully used it many time with the dir map from
r.watershed...
Maxi
On Tue, 14 Mar 2006 01:13:49 +0000
José Miguel Delgado <jmmd at mega.ist.utl.pt> wrote:
> Hej,
> I am trying to get a catchment from r.water.outlet
>For that I am using a drainage direction raster that I
>obtained from r.fill.dir, using type "answers"
> I have tried several times with different coordinates
>for the outlet, but all I got was a raster full of zeros.
> Am I doing something wrong? (possibly the input for
>r.water.outlet is not a "answers" type or I have been
>choosing bad points with local distubances in topography
>for outlet - .hgt 90 m res)
> Thank you for your help,
> José Miguel Delgado
> +351 96 640 72 09
> +46 73 573 23 89
_
Eng. Massimiliano Cannata
Geomoatic Phd student
www.ist.supsi.ch
