[GRASSLIST:103] Re: v.in.dxf
Michael Barton
Michael.Barton at asu.edu
Tue Mar 14 14:36:01 EST 2006
We need someone willing to write a dxf in/out module for GRASS. Using OpenDWG libraries is only a partial solution.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
-----Original Message-----
Sent: Mon 3/13/2006 12:11 PM
To: "Carlos \"Guâno\" Grohmann"; grasslist at baylor.edu
Subject: [GRASSLIST:51] Re: v.in.dxf
Sorry for the cross-post, but I'm trying to do almost exactly the
opposite. That is, export a (raster) DEM to dxf. I was browsing the
diverse grass modules, and the problem is I couldn't find a way to
convert a raster DEM to a vector "surface" or "3d" file. So I can later
export it using v.out.dxf. I tried r.to.vect with horrible(and maybe
simply "not applicable") results.
I found some (non- free) programs that seem to do this (r2v, from
ablesoft, by example) but it intrigues me if it can actually be done
with grass(or with free software).
Thanks,
Mauro
Carlos "Guâno" Grohmann wrote:
>Stefan, you might want to take a look at OrbisCAD (please search
>Google, I don't remember the URL, but I know it is in Sourceforge).
>According do the authors, it can read DXF and export shapefiles.
>Hope this helps
>Carlos
>On 3/13/06, RAVI KUMAR <ravivundavalli at yahoo.com> wrote:
>>Stefan Gasser <stefang at dnet.it> wrote:
>>Hi
>>I`m using grass61 on windows and would like to import dxf and dwg files, but
>>it is only possible with dgn files using v.in.ogr.
>>Is there any other possibility to do an import for AutoCad files?
>>v.in.dwg requires OpenDWG toolkit. To get this toolkit you must become at
>>least "Associ! ate Member" of OpenDWG Alliance (http://www.opendwg.org), it
>>is free-of-charge (you have to fill one form).
>>Then unpack library and copy to this directory:
>>ad2.a ad2.h odio.h adinit.dat
>>and compile this module.
>>Ravi Kumar
>>thanks
>>Stefan Gasser
>> ________________________________
>>Yahoo! Mail
>> Bring photos to life! New PhotoMail makes sharing a breeze.
> Carlos Henrique Grohmann - Guano
> Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
>Linux User #89721 - carlos dot grohmann at gmail dot com
>_________________
>"Good morning, doctors. I have taken the liberty of removing Windows
>95 from my hard drive."
>--The winning entry in a "What were HAL's first words" contest judged
>by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
