[GRASSLIST:123] Re: Connecting to remote MySQL server
Rainer M Krug
rkrug at sun.ac.za
Wed Mar 15 03:30:07 EST 2006
Hi Stephan
thanks a million - it is working now.
db.connect driver=mysql
database="host=ecolmod-mysql,dbname=renpatch_renosterbos"
is the right syntax
Rainer
Stephan Holl wrote:
> Hello Rainer,
> On Wed, 15 Mar 2006 09:10:09 +0200 Rainer M Krug <rkrug at sun.ac.za>
> wrote:
>> Hi
>> I compiled GRASS 6.1 with MySQL support, and I have the option to
>> connect to a MySQL database. But it seems that I can only connect to
>> a locam MySQL database, as in the db.connect, I didn't find any
>> parameter for host name which I could specify.
>> Can I connect to a remote MySQL database (I guess I can...) and if
>> yes, how; where can I specify the host name of the MySQL server?
> At least for Postgres is an example stated in the manual-page :
> see
> g.manual db.connect
> db.connect driver=pg
> database="host=myserver.itc.it,dbname=mydb,port=6666"
> db.login user=myname pass=secret db.
> connect -p
> db.tables -p
> You might check this out with mysql. (I cannot, since I do not have
> mysql running here).
> Hope this helps.
> Stephan
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation Biology (UCT)
Department of Conservation Ecology
University of Stellenbosch
Matieland 7602
South Africa
Tel: +27 - (0)72 808 2975 (w)
Fax: +27 - (0)21 808 3304
Cell: +27 - (0)83 9479 042
email: RKrug at sun.ac.za
Rainer at krugs.de
