[GRASSLIST:191] Re: Problems with installation
Julie Tittler
julie.tittler at operamail.com
Thu Mar 16 22:27:09 EST 2006
I have followed the below instructions, and yet rpm still tells me that it cannot find the libsqlite3.so.0 library. When I do a find for the libsqlite3.so.0, I get the following:
/usr/local/lib/libsqlite3.so.0
/usr/lib64/libsqlite3.so.0
/usr/lib/libsqlite3.so.0
/home/julie/Desktop/libsqlite3.so.0
/libsqlite3.so.0
The file actually resides in /usr/lib64. All the other references are soft links I created to try to get it to work. Where can this thing possibly be looking for this file? Any ideas what I'm doing wrong?
Thank you,
Julie
> > I'm trying to install GRASS on an AMD64 machine running Fedore Core 4.
> > I have downloaded the Fedore Core 4 files. I have installed many of
> > the rpm's, but I cannot get gdal to install. It's unable to locate
> > the libsqlite3.so.0 library. When I go to install it, it tells me
> > it's installed already. So, if SQLlite is already installed, what's
> > going wrong? Any ideas on how to fix this? GDAL is the part I really
> > need to use.
> funny, it should be installed with sqlite:
> http://rpmfind.net//linux/RPM/fedora/4/i386/sqlite-3.1.2-3.i386.html
> rpm -q sqlite
> Sqlite 3 may be installed, but it doesn't necessarily contain a file
> called libsqlite3.so.0.
> try
> ls -l /usr/lib/libsqlite3.so*
> and see what shows up. If something close is there, you might just need
> to make a symlink to it with the desired name.
> e.g.
> cd /usr/local/lib
> ln -s /usr/lib/libsqlite3.so libsqlite3.so.0
> or
> ln -s /usr/lib/libsqlite3.so.0.8.6 libsqlite3.so.0
> make sure /usr/local/lib is listed in /etc/ld.so.conf so it can find
> your new link. If not, add it and run ldconfig (as root) to refresh the
> installed library list.
> Hamish
> -- Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
