[GRASSLIST:196] Re: trouble using v.in.ascii
Stefan Istvan
stefi at geohidroterv.hu
Fri Mar 17 01:24:22 EST 2006
On Fri, 2006-03-17 at 11:30 +0530, Vishal Mehta wrote:
> Hi all,
> I'm trying to bring in a comma separated text file as a point vector
> file in GRASS using v.in.ascii, before i try to link it to a large
> 33Mb dbf data file.
> The csv file looks like this with 39 rows and i removed the header
> because grass60 (on Ubuntu breezy) does not have the skip option in
> the v.in.ascii command: the columns are WMOID, cityname, Latitude and
> Longitude. I want to use the WMOID as 'cat' in order to link my dbf
> data later.
> 420710,AMRITSAR,31.63,74.86
> 421010,PATIALA,30.33,76.46
> 421310,HISSAR,29.16,75.73
> 421820,DELHI,28.58,77.20
> 423390,JODHPUR,26.30,73.01
> 423480,JAIPUR,26.81,75.80
> 423690,LUCKNOW,26.75,80.88
> 424100,GAUHATI,26.10,91.58
> I Tried the following command and got the error:
> cat reformat/STATIONS2.dat | v.in.ascii output=stations2 fs=','
> columns='cat int, name(varchar(30), y double, x double' x=4 y=3 cat=1
> WARNING: DOS text format found, attempting import anyway
> Maximum input row length: 39
> Maximum number of columns: 4
> Minimum number of columns: 4
> column: 1 type: integer
> column: 2 type: string length: 18
> column: 3 type: double
> column: 4 type: double
> DBMI-DBF driver error:
> SQL parser error in statement:
> create table stations2 ( cat int, name(varchar(30), x double, y
> double )
> Error in db_execute_immediate()
> ERROR: Cannot create table: create table stations2 ( cat int,
> name(varchar(30), x double, y double )
> I also get the same error with
> v.in.ascii input=reformat/STATIONS.csv output=gstations fs=',' skip=1
> columns='cat int, label(varchar(30), y double, x double' x=4 y=3 cat=1
There is an additional "(" sign in your columns definition. You should
write columns='cat int, label varchar(30), y double, x double'.
The other problem maybe that your file is in MSDOS format, but it could
be that it doesn't bother Grass. Try to use dos2unix command to convert
it to unix format.
Regards,
Istvan
