[GRASSLIST:235] Re: making a "true-color" landsat composite
maning sambale
emmanuel.sambale at gmail.com
Fri Mar 17 18:57:28 EST 2006
Great! thanks!
On 3/17/06, Markus Neteler <neteler at itc.it> wrote:
> On Fri, Mar 17, 2006 at 01:45:35AM -0800, maning sambale wrote:
> > Hi,
> > two things:
> > 1. simple label mistake on the GUI (see attached)
> thanks, fixed.
> > 2. erros below. Im using huidae's binary on cygwin running on XP.
> > i.landsat.rgb blue=tm2001_7 green=tm2001_4 red=tm2001_2 output=test
> > Sorry, <per> is not a valid parameter
> > Description:
> > calculates univariate statistics from a GRASS raster map
> > Usage:
> > r.univar.sh [-e] map=string
> You need to get r.univar.sh from GRASS 6.1 (the windows binaries
> are apparently too old and do not contain the updated
> r.univar.sh). I think that you can grab it from the
> CVS Web interface and simply update on your machine.
> Make a backup of the original r.univar.sh script of
> course.
> good luck
> Markus
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |Philippine Biodiversity Web Map |
| _)_/LI |www.geocities.com/esambale/philbiodivmap/philbirds.html |
