[GRASSLIST:282] RE: r.out.gdal problem
Patton, Eric epatton at nrcan.gc.ca
Tue Mar 21 10:47:01 EST 2006
When you say graphic, do you mean a non-georeferenced image? I'm guessing,
maybe r.out.gdal is only good for georeferenced images. Have you had any
luck trying 'gdal_translate -of JPEG input output'?
~ Eric.
-----Original Message-----
To: grasslist-en
Sent: 3/21/2006 10:18 AM
Subject: [GRASSLIST:281] r.out.gdal problem
Hello,
I somehow don't completely understand the usage of r.out.gdal. I
prepared a graphic (which is an imported tiff) with r.composite. I can
export it with r.out.tiff without any problems. But how can I use
r.out.gdal to export it as JPEG (or GTiff with TILED=YES). I always fail
to specify the correct option for the required "type". I already tried
every possibility which is listed (Byte, Int16,...), but without
success. What "type" do I have to use?
Thanks
Wolfgang
