[GRASSLIST:283] Re: r.out.gdal problem
    Wolfgang Zillig
    wollez at gmx.net
    Tue Mar 21 10:59:43 EST 2006
To make it clear, I have a georeferenced raster grafic. r.out.tiff
works, and I can do successfully:
C:\Documents and Settings\s0167070>gdal_translate -of GTiff -co
TILED=YES -co CO
MPRESS=JPEG -co JPEG_QUALITY=65 in.tif out.tif
(But I have to say that I also have FWTools installed on my computer, I
haven't tried with cygwin)
Is it possible to export a raster file with the command given above?
Grass always complains that I have to specify the "type", which I don't
know.
Wolfgang
Patton, Eric schrieb:
> When you say graphic, do you mean a non-georeferenced image? I'm guessing,
> maybe r.out.gdal is only good for georeferenced images. Have you had any
> luck trying 'gdal_translate -of JPEG input output'?
> ~ Eric.
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> To: grasslist-en
> Sent: 3/21/2006 10:18 AM
> Subject: [GRASSLIST:281] r.out.gdal problem
> Hello,
> I somehow don't completely understand the usage of r.out.gdal. I
> prepared a graphic (which is an imported tiff) with r.composite. I can
> export it with r.out.tiff without any problems. But how can I use
> r.out.gdal to export it as JPEG (or GTiff with TILED=YES). I always fail
> to specify the correct option for the required "type". I already tried
> every possibility which is listed (Byte, Int16,...), but without
> success. What "type" do I have to use?
> Thanks
> Wolfgang
