[GRASSLIST:313] Re: Compiling gdal with grass support: need help on '--with-grass=' p ointer
Matthew Perry perrygeo at gmail.com
Wed Mar 22 12:02:49 EST 2006
Eric,
  When you compile GRASS, are you sure it's picking up on you local
installation of GDAL? Try explicitly setting
--with-gdal=/usr/local/bin/gdal-config
Also, instead of recompiling GDAL, I think the prefered method is to
use the GDAL-GRASS plugin. It's fairly simple once you have gdal and
grass installed, though I think it only works for recent (> 1.3.1 )
versions of gdal:
wget "http://www.gdal.org/dl/gdal-grass-1.3.1.2.tar.gz"
tar -xzvf gdal-grass-1.3.1.2.tar.gz
 cd gdal-grass-1.3.1/
./configure --with-gdal=/usr/local/bin/gdal-config
--with-grass=/usr/local/grass-6.1.cvs
- matt
On 3/22/06, Patton, Eric <epatton at nrcan.gc.ca> wrote:
> Following Dylan's tutorial (http://169.237.35.250/~dylan/grass_user_group/)
> on getting Grass cvs installed, I got surprisingly far before running into a
> compile error:
> Downloaded latest cvs from repository into /usr/local
> compiled gdal --without-grass, no problems (used the script on Dylan's site)
> ./configure for grass cvs, all dependencies met:
> ./configure --with-png=internal --with-jpeg=internal \
>         --with-gif=internal --with-libtiff=internal \
>         --with-geotiff=internal --with-libz=internal\
>         --without-pg --without-ogdi --with-python \
>         --with-threads=yes --without-grass \
>         --enable-largefile
> make
> make install
> ldconfig
> And no problems. Now I'm trying to configure gdal with grass support, again,
> using the script provided on Dylan's site:
> --with-threads=yes --with-grass=/usr/local/grass6/
> and received error message:
> configure: error: --with-grass=/usr/local/grass6/ requested, but libraries
> not found!
> So where should the '--with-grass' flag be pointing to? I've read
> conflicting information on the archives that the path inserted for this flag
> should be everything from the binary
> (/usr/local/grass6/bin.i686-pc-linux-gnu/grass61) to a symlink in /usr/lib
> that points to grass libs somewhere else.
> I'm able to run grass-cvs normally, except of course I can't use r.*.gdal,
> but everything else seems fine so far.
> ~ Eric.
Matt Perry
http://www.perrygeo.net
